Epson x800 said that it could not recognize Epson photo black 273 cartridgelage. I immediately replace it with,another same cartridge PDK 273 that I had bought separately from Best Buy (the other black was with the other colors bought from Epson. Now it says it will no recognize the Black double cartridge. Is there something I can do?
Hi.
try this link might help you get it sorted.
Epson will not recognize it own cartridge Google Search
SOURCE: Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
SOURCE: Epson Stylus Color 660 won't print in black
hi i want driver epson 660 in windows xp pls help me
SOURCE: Epson DX8400 cartridge
i have come across this often and bought a chip reset tool from ebay .
you can also buy the software reset for the printer it worked for me
SOURCE: Epson DX8400: how can i get it to print black only
Sorry Desperate. All inkjet printers, from all companies, are programed to only operate with ink in all containers to avoid other problems. Their is no workaround. Please rate me not harshly just because you don't like the answer. Rate based upon the truth of an answer.
SOURCE: Cannot print black on epson cx7400
I've had nothing but problems with Epson cartridges and drying up of ink. If the cartridge is a little old, say a few months, then don't be surprised if its dried up. especialy if its in warmer weather near a window.
If its new, then make sure that the tape is remved from the cartridge [obvious but I thought I'd mention it].
Also, its expensive, but you shodu lonly use genuine Epson ink cartirdiges adn not genreic brands or refills.. having spent coutless hours reparing ruined printers because someone thought they could save a few bucks.. it ain't worth it in the long run.. buy the genuine ink adn use good quality paper..
