After formatting, it will be blank. You can't copy from one to another, but if you used itunes to load the classic, itunes can load the contents to the nano.. If some content was not loade via itunes, it won't get loadedc on the nano, unless you buy a utuility to copy.
Apple Inc.Nov 11, 2015 - And with AirPlay Mirroring, you can display your iOS screen on yourApple TV. ... For music: Apple TV, AirPort Express, or AirPlay-enabled speakers. ...iPhone 5 or later; iPad mini or iPad (4th generation or later); iPod touch ...
Apple Inc.Contents. 1. Connect. 2. Configure. 7 What's in the Box. 8 What You Need. 10 Apple TVat a Glance. 12 Setting Up Apple TV. 18 Network Configuration.
yes, you will need an apple TV set up with your television. set up your apple tv with your television, connect to the wifi network on both devices and your screen will be mirrored
With iOS 4.2 you can create a playlist in iTunes, drag the video into the play list, play it in iTunes and hit the "Loop" button in the lower left hand corner. Then use Airplay to stream the video to the Apple TV. The new black ATV will work out of the box, you can jailbreak the old ATV with ATV Flash and install RemoteHD under apps and then you can stream to the old ATV using the same method.
go to /Library/Application Support/Conduit/Plugins/cttoolbar.bundle/Contents/MacOS/ct_plugins
right click on it and click "show contents" or "show package contents".
delete the plists listed here http://discussions.apple.com/thread....sageID=9913691
