Question about Sharp AR-5316 Advanced Digital Imager Copier
Call for service . code : F2 - Sharp AR-5316 Advanced Digital Imager Copier
    New Friend:
  • 28 Answers
There are several F2 codes. If you press and hold the start / copy key the machine will show your sub code. Re-post quoting full code and we can try to help.
Posted on Jan 27, 2014
Testimonial: "Hi problen is this!there isn't sub cod . when i press Start that make a Copy ! i have a problem with this . Error F2 Withut Sub cod"
6ya staff
SOURCE:
Mx-5000n error code f2
Hi Saman,
Usually there are other numbers after the F2 part of the code. If you let me know the full number I can tell you what is wrong. However the family of F2 codes indicate a wide variety of sensors usually in relation to the process of making color copies.
You should call on your local dealer for service.
Apr 15, 2016 | Sharp MX5001N copier w/ 36 Month Warranty
How do i clear error code F2-64
The news is not good. Follow the link to see what you are up against.
Error Codes Sharp MX2310U Code F2 64
Mar 04, 2015 | Sharp MX-2310U Color Copier, MX2310U "
Sharp MX-181OU-Call for Service. Code: F2-40 How do i fix?
SOURCE:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=MXM363N&code=F2-40
Seems to be a black toner supply issue. Try a different black toner cartridge. Also, make sure the sealing tape has been removed, and give the cartridge a good shake before inserting. Also could be waste toner cartridge, or even the developer, but we always hope for the least expensive option first!
Feb 11, 2015 | Sharp Office Equipment & Supplies
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Sharp ar-m205 f2 error code blinking instantly and device doesn't go to service menu
hello,
F2 04 Improper cartridge (destination error, life cycle error).
Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one.
the toner cartridge seems to be the problem.
regards,
Adi
Nov 05, 2010 | Sharp AR-M205 Copier
What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Dec 16, 2008 | Sharp AR-207 Copier
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
