SOURCE: Dodge Ram B250 1994 - has a Starting Problem
if you van has a security system in it, it could be causing this problem. they usually disable the starter circuit. Paul has listed good places to start. but if they don't fix it do this: when your trying to start but its not working have some one check voltage at the starter. there are 3 points to check 1: where battery cable connects 2: where starter connects to solenoid 3: small wire that operates solenoid. if there is voltage at all three point replace starter it has a shorted / open spot on armature. voltage at 1 and 3 but not 2 replace solenoid. voltage at 1 but not at 3 and you have already checked the items Paul identified check wiring between neutral safety switch and solenoid.
SOURCE: car won"t start. starter turns. Happened once before. started after 30-45min.
I would start by banging the bottom of the gas tank while you are cranking it over. If this causes it to start, replace the fuel pump. If it still doesn't start, there is a valve on the fuel rail on the top of the engine (you may have to remove plastic cover). Remove the plastic cap on the valve, and while you have someone cycle the ignition to the run position from the off position, depress the center tab on the valve and see if gas comes out. If it doesn't, replace the fuel pump. If it does, let me know and I will help you further. (note: replace fuel filer at same time.)
SOURCE: Intermittent Starting Issues with 2003 Acura MDX
if its a diesel you have to turn it to position 1 till the heater plug light goes out try it twice on cold days.joe
SOURCE: my 2000 ford explorer suddenly wont start... the
does the battery have a full charge to it? If so clean battery terminals and chck battery cable at starter make sure its getting good contact. Make sure battery ground is making good contact at engine. Can you jump the car off? If so take off positive battery terminal while the car is running if the car dies altenaters bad replace it.
Testimonial: "will submit my testimony after i try the advice, but i asked for help in getting my hood opened also, which i guess they forgot to answer. "
SOURCE: 2006 Jeep Commander Intermittent Starting Problems
Common problem in snow country where salt water can corrode starter parking gate wire connection at started tab. Just cleanthe connector and tab, coat in dielectric grease, problem solved in 15 minutes!
