I need to blow up an air mattress and I heard you can do it with a vacuum. How can I reverse suction on my Hoover Elite Rewind vacuum so It can blow out air?
SOURCE: Hoover Steam Vac Model F5826-900
When you put the lid on the recovery tank, you have to be sure that the front of the lid is properly engaged into the two tabs on the top of the tank. With the lid installed, if you can lift the front of the lid off the tank with two fingers, then the lid is not on correctly. Also, make sure the square duct that goes into the front of the tank is in place. You have to remove this duct to install the hose for doing furniture but must replace it to go back to the floor function. By the way, the "blowing air" you refer to is normal. This is exhaust air from the motor and it is used to propel the solution onto the carpet.
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: hoover eite rewind vacuum has blocked airflow, how do i fix?
i had the same issue, but with a little time and a screwdriver, i got my vacuum working like new.
First, remove the bottom cover where the brush is located. Once the cover is off you'll see the vacuum inlet hose just behind the brush. Clear out any debris you find in there.
Second, on the back of the unit, where the attachment hose connects to the vacuum remove the three screws and clean out any debris you see in there. (dont be afraid to get your hands dirty)
hope this helps!
Country Music Guy
SOURCE: how do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
