Hi just read your post.Now when the machine beeps a series of lights will light up on the wash progress lights. The spin light is number 8 and the other end of the lights is number 1 which is long wash, i think. Starting from the long wash light which is number 1, which lights are on when the machine is beeping, is it 1,4 and 7 or 3, 7 and 8 etc? Please reply with the answer to this question and i am sure i can help you. Regards Lu
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
SOURCE: starts and stops
Fisher & Paykel GW708\r\nWashing machine stops and starts filling then starts beeping and the long wash light 1 and the 7th light are lit up. If I turn off the power I can restart and eventually fill machine but it will error again when it needs to fill up again.
Please help.
SOURCE: fisher and paykel smart drive
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
SOURCE: fisher and paykel excellence smart
most likely you have a bad drain pump.or its possible you have foreign objects inside the drain pump preventing it from operating
