This problem has only been apparent for the last 2 months. The indication light occasionally switches from stable blue to blinking, without the interference of the remote control. The screen is a constant black, and will not respond to any functions on the remote (i.e. power on/off, input, etc.).
SOURCE: 16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: Red light power indication is on. When I push
Any sound? The problem can be due to bad 24vdc power supply due to bad caps or failed components, bad backlights inverter boards, bad main board. You need to troubleshoot it to really locate the bad board/s.
Please read my guide first so you will know what to look for inside.
Service manuals (one of these should match your chassis):
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=42LB5D&kategoria=&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
