Question about Dean Guitars Dean Edge Quilt 5 String Bass Trans
Dean Edge 5 wiring diagram
I have a Dean Edge 5 active bass purchased about 6 years ago. Quilted top, blue. While it has a modern tone it's developed a static noise at all volumes. I replaced the battery but still got the same results. I checked the input jack and it seems to be OK. The soldered connections are clean and solid. Aside from taking it to a guitar repair shop, does anyone else have this issue? If so, how do I resolve this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 829 Answers
Http://www.guitar-repair.com/
Posted on Jan 25, 2014
2 Suggested Answers
6ya staff
SOURCE:
Michial Gueffroy
  • 1140 Answers
SOURCE: I have a Hutchins bass which is semi hollow and
Here is their contact info:http://www.hutchinsguitars.com/contact.aspx I'm sure they would be able to help you.
Posted on Jul 13, 2010
Peavey Fury 4 Quilted Bass guitar serial number 01050957
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
Apr 10, 2014 | Peavey Music
Dean Edge 4 Bass electronics quit working
Clean the contacts on the input jack and battery jack.
Sep 06, 2017 | Dean Edge 4 Bass Guitar
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
I need wiring diagram for ibanez gsr200 bass guitar
Here is a diagram:http://forum.ibanez.com/default.aspx?g=posts&t=78892
Jul 01, 2010 | Dean Edge 4 Bass Guitar
What is the Schematics to the dean metalman v bass?
Should be pretty simple, one pickup, one volume control, one tone control:http://www.deanguitars.com/metalman_series.php Try here:http://www.deanguitars.com/services.php Toll free phone number.
May 10, 2010 | Dean Edge 4 Bass Guitar
Dean edge bass quits
The wiring in the back is so very thin and the circuit board isn't attached to anything but the wires that are attached to it. I found two weak solder joints there and one in the battery compartment (you'll have to remove it to get to the solder joints). I don't know which repair did the job, but it's working for now, anyway. I'd like to replace the tiny wires but there's not enough room in that compartment. I, also, had to replace the 4 bridge screws with larger diameter SS screws months ago as ALL 4 were stripped. Thread too fine for wood that soft. Come on Dean, step it up a notch! The bass plays and sounds great.
Feb 24, 2010 | Dean Edge 4 Bass Guitar
I need to know where to soder the wires inside the bass guitar
At this site find a guitar diagram that matches the resources of your guitar to find a suitable schematic.
http://www.guitarelectronics.com/category/wiringresources/
Dec 30, 2009 | Dean Edge 4 Bass Guitar
Wiring for a dean edge 4 string with one soap bar pickup
You might find it at http://www.mediawebsource.com/guitar/pickup.htm If you can figure out what brand the pickup is you could check the manufacturers site. http://www.guitarelectronics.com/category/wiringresources/ has original factory wiring diagrams for guitar and bass for various pickup manufacturers. Hope this helps.
Jul 10, 2009 | Dean Edge 4 Bass Guitar
Dean Guitars Dean Edge Quilt 5 String Bass Trans Logo
330 people viewed this question
Top Dean Guitars Music Experts
Michial Gueffroy
Frank
tmaree
tmaree
Are you a Dean Guitars Music Expert? Answer questions, earn points and help others
