Question about Westinghouse SK-32H540S 32 in. LCD TV
Remove stand from a Westinghouse LCD HD 32in TV SK32H240s
I want to remove the stand so that I can mount it onto a wall mount that I have ready. How do I remove the stand.
6ya staff
SOURCE:
SOURCE: Where can we find a TV pedestal stand
You will have to send them an email on there website here's a link to the contact us page
CLICK HERE
Tell them you need to buy a replacement stand and give them the model number of the TV. They will reply with an amount and payment methods. Ive done this before for replacement remotes and monitor stands. Good luck and have a good day, Dantechcom.
Posted on Jan 05, 2009
Anonymous
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
Anonymous
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
Anonymous
  • 66 Answers
SOURCE: i bought a 27
Yes, you can purchase the stand to your television through ebay.com
Posted on Jul 29, 2009
Anonymous
  • 245 Answers
SOURCE: How to wall mount
u have to get a wall braked to do this.......go to a store where they sell televisons and they will help u with ur problem.....also it eill have a installation guide enclosed in the carton
Posted on Nov 28, 2009
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Set up for lg cs570
Some stands come with a mount that looks like a wall mount, ready to mount to the TV. If not then use the table top stand that came with the TV
Jan 02, 2014 | LG 42" Cs570 Series Black Flat Panel Lcd...
I have a westinghouse flat screen tv model sk32h240s that has no picture but sound works. I have replaced a bad transformer and checked and replaced all the capacitors that were bad. What else should
Depends on what type of input your using. Maybe try dif cord( hdmi,component video or composite video) or try dif input on tv. Verify source has video out on dif tv or try dif source.
Jul 25, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
2)Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3)Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4)Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Out Westinghouse has the feet as shown in the
Hello, the way to remove the two stands on this model is to remove the two speaker panels on the sides, you will have 6 screws to remove (three on each side) on the bottom by the feet, after you remove the screws the feet should come right off. Please rate my help if it was helpful.
Feb 01, 2010 | Westinghouse W33001 30 in. HD-Ready LCD...
How to wall mount
Nov 28, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
CLICK HERE
Jan 05, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
We bought a Westinghouse 32in TV from Walmart, and because it was on display, it did not come with a pedestal stand, i wanted to know if there was any way for us to get that, because the apartments we live...
CLICK HERE
Westinghouse SK-32H540S 32 in. LCD TV Logo
65 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
