Regent model ht-2004! volume down button is stuck or something like that, and the speakers are not making any sound. whenever I turn on the speakers they go from normal sounding all the way down to mute! what is the problem? can it be fixed? or should i go get a new one?
SOURCE: Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
SOURCE: STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK [email protected]
SOURCE: Technics SA-DX950 has lost digital sound
This may sound like a silly check, but verify that the tape monitor switch is not engaged. What is the quality of the sound when turned up? Is the cound clear or raspy?
Thanks,
Dan
SOURCE: no sound from my ht r520 6.1 model
I have the same problem. No sound on the speakers or on the headphones.
SOURCE: Need to find code or
You can get the manual and codes on the link below. If you do not see your receiver then do a code search on page 9 under SEARCHING FOR TV, AV1 OR AV2 CODES.
Here is the only code in the manual for you receiver.
Regent 31437
Page 9 under CONTROLLING OTHER COMPONENTS will tell you how to enter the code.
Here is the manual on the link below.
http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC65forWeb.pdf
Good Luck and please rate 4 thumbs up for the free answer
take a flathead and pry it out of the housing and use a pencil eraser to change the volume from now on. the button itself is behind the plastic button switch that's stuck down.
