Brushes not moving are usually caused by the turbine bearing seized. This job requires the turbine to be removed, completely dissassembled, cleaned new bearings and then re assembled and installed. The tank is another part, if your tank does in fact need replacement then the normal cost is between 45-60 dollars. Even if he completely replcaed the turbine, those cost about 35-45 dollars. I do know that the new tank style (all clear) is made much better than the original (2 color). This model is a good one. you are getting to the 50% of cost for a new model. if you get this one fixed make sure they install a gasket under the turbine, to prevent further issues.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/robert_b96ba3f038cf317c
