I removed my battery because i'm not using it for a long time but then when I put back the battery to use it, my instax won't open. I tried changing the battery but it is still not working. What should I do?
SOURCE: I have a Fuji Instax
The same thing happened to me. Make sure that the mechanism arm on the inside that pushes the picture up is connected with the metal piece on the right hand side. The two can come loose allowing the metal piece to not bring the arm with it when you take a picture. Also the roller could have fallen down a bit. From the inside, press the roller up (it will click when it is in the right spot). The roller should be even all the way across and pushed all the way to the top of the camera.
I hope this helps if you haven't been able to fix it already.
(When all else fails, try changing the batteries.)
SOURCE: I just loaded my new
Well, black prints on an instant, or any camera, mean that they're unexposed. So, there are a few things to check - but in your case all will probably mean losing your remaining photos.
First, when you loaded the film, did you remove, or did the camera spit out, the initial black cardboard leader? If not, this is the source of your problem. This piece must come off the film pack first otherwise nothing else is going to work.
If that came out and you're still not getting photos, you're going to need to verify that you're both using the camera properly, and that the camera is functioning properly.
You'll need to be sure that you're getting enough light to get a good photo - darkness isn't going to give a good picture, but in some situations with some high speed films, neither is too bright of a condition. I've had this problem with my polaroid camera. The camera can't compensate for an extreme high-speed film and bright sunlight so it's not even giving an exposure. Don't ask me why, but it happens. If there's an option to change settings for outdoors/indoors, try that.
If that's also not your situation, you'll need to find a way to verify that the camera's shutter is actually opening and working properly. That's easier said than done, but if the other two situations don't help, feel free to contact for further assistance.
SOURCE: I put a fresh new
try to take a few more photos or try use pack of films.
If same things happen, mean the shutter lens is spoil. it don't allow light to enter and develop the films.
Send it to repair shop to fix it
