Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers Logo
o
oliver abela Posted on Jan 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Single speed i have an andis agc2 speed and recently it was only working on a single speed therfore when i switch from speed 1 to speed 2 doesnt increase the speed. As i saw that the motor is running i tought the circuit board was gone. I have ordered a new circuit board and changed it but still the same problem,my question is the armeture faulty or maybe the new board ive bought is faulty? Thanks.
adam adms
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 829 Answers
  • Posted on Jan 25, 2014
adam adms
Master
Level 3:
Renaissance:
Answers
829
Questions
0
Helped
69972
Points
2193
Maintenance must be done and clean the engine
My Andis Agc2 speed is powering fine until i engage the blade. Seems to have lost the ability and power the move the blade. I remove the blade and it seemingly runs fine ?
The blade assembly is either jammed or broken. I would remove the assy and test to see if it runs. If I you have isolated it to the blade assembly. (If not its internal and needs factory service).
Heres a link to the manual. The graphical instructions for removing the blades are on page 4.
https://www.manualslib.com/manual/716350/Andis-Agc2.html?page=5
Clippers wont turn off?
Sounds as though the switch is faulty on the circuit board you can purchase new Andis parts here Dog Clippers
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
I removed the blade assembly on the andis agc 2 by mistake,how do i fit back together it doesnt seem to fit
Instructions come in with a new drive assembly, basicly put the black end through under the metal frame first then push it down into place.
Do you have a user manual for Andis 2 speed dog groomers
http://www.andis.com/USA/service/PartsListUseCare.asp?div=Information
I have an Andis AGC 2 speed and I cannot figure out how to get the blade on and make it stay on when I turn on the clippers.
Ok you should be connecting the blade whilst the clipper is on this will ensure the blade engages with the clipper correctly, simply push the front edge of the blade into the clipper untill the latch has snapped into place.
Speed changes on it's own and sometimes it only has one speed. wondering if it is the motor or switch?
Neither the circuit board need jacking up with a washer either side or worst case a new Circuitboard.
My andes agc2 doesnt run. i opened it and noticed the round cylinder ( which says 105 GR) was not connected to anything. how do i hook it up?
This round cylinder is a permenant magnet and doesn't actually connect to anything, the only contact which matter are the copper wires connecting the circuit board to the Carbon brushes.
This may be as simple as a faulty cable check for power to the circuit board.
Top Andis Pets - Others Experts
Kardoc
Muhammad Tanveer
Sierra
Sierra
Level 1 Expert
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
