When the belt broke from the Rainbow R2800C, I went to replace it only to find out that the part where the belt attaches to is missing. I have no clue to what this part even looks like so I was wondering if it can be replaced or if someone has a picture of what the part looks like so I can make a replacement part to work.
SOURCE: Replacing Belt
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
SOURCE: eureka model 4870 belt replacement
- NO WAY AROUND THE END OF THE DRIVE SHAFT TO REMOVE DAMAGED BELT.
Does your machine have a slipped bushing? You may be able to fix it without taking it apart any more than for a normal belt replacement. Try using a rubber or plastic-tipped forceps or pliers move the bushing back into position. Be careful not to mar the metal as it will chew any new belt to bits in seconds. If you are able to move it, put on a few drops of LokTite, epoxy or some other adhesive to keep it in place. You may be able to avoid sending your vac to the shop for costly repairs.
SOURCE: Self-propel switch arm broke off where control
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
