HEWLETT-PACKARD HP??? Pavilion DV6-3231nr Entertainment Laptop (2502164) PC Notebook Logo
T
Tejinder Singh Posted on Jan 25, 2014
I have hp pavilion dv6-3231nr entertaitment pc when em trying to install window xp on my laptop after loading drivers the blue screen appears every time....plzzz help me out
2 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Jul 17, 2011
SOURCE: hi, i need Windows XP
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Anonymous
  • 408 Answers
  • Posted on Sep 23, 2011
SOURCE: hi, i want ot install windows
(Copy and paste to browser) b> Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA! Bestregards,
Junior
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
'' a problem has been detected and windows has shutdown to prevent damage''
From the description it is the hard drive that is the problem, format the whole hardware and re-install your xp windows to see if that will clear up the problem, if not! have the hard drive tested to see if it must be replaced.
Hi, i want ot install windows xp on hp pavilion dm4 - 1165dx entertainment notebook. i have 500gb of hard drive and 4 gb of RAM but when ever i tried to install xp a blue screen is appear. how to resolve...
Junior
I need video controller driver for hp pavilion dv2530ee model xp base from where i can down load?
Hey!
I don't know your exact laptop model, so there are 2 options:
Both driver are for WINDOWS XP.
If you don't know which one is installed in your laptop, refer to it's manual or the original discs than came with it (even if they're not for Windows XP) - OR just try BOTH - then uninstall the irrelevant one. Anyway, you'll need to restart your computer after (each) installation.
Hope I helped,
Pelu.
2helpful
2answers
I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
3helpful
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
4answers
Unable to install winXP on my new HP Pavilion dv5
this problem is hardware inside your PC.. or unable to detect the device for the installation of your new system
How can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Blue screen
If  you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps...
6answers
Sound device problem
The problem is the software driver that will make your sound device is not installed.install the device driver.this wiil cure the problem.
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
