With a flat screen TV, this is a bad symptom indeed. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Screen shots to defective flat screen TV are given. You can compare it to your TVs' screen and can make sure about the fault.
Testimonial: "40 years this the best you can do :) what a joke !!"
SOURCE: why cant i get my tv to turn on ?
just worked on one of these, same problem, found a bad capacitor,1000uf 25volt, in power supply module.
SOURCE: Red lights is on and when I go to turn on the TV
Your external power supply is the culprit. The small box that is connected the outlet plug is bad. The TV itself is fine! The external box has a bad capacitor inside. You will find a 16 volt 1000MF capacitor at 105 degrees that is bad and next to that one is a 25 volt 1000MF at 105 degrees, replace as well! Show this info to your TV tech or hobbiest and repairs will be at hand. Thanks for asking and good luck!
