I can't hear or import audio using the Canopus ADV-55.
I am using iMovie as the import program.
I can see the video just fine.
The small switches on the Canopus are all in the "up" position except for #2 that is in the "down" position.
Can anyone help?
Thanks.
SOURCE: cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
I'm
sorry but I believe you have this posted in the wrong product
category? Please re-post the question in the proper category if this
is the case, otherwise you have my apologies. This is the car and
truck problem category
