When I try to mark new waypoint the message appear " Waypoint memory is full " also the memory Micro card is empty.
SOURCE: Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
SOURCE: route waypoint memory full
from the main menu select FIND. Select WAYPOINTS, press the menu button ( bottom on LHS of unit) Select DELETE from the menu, choose what you want to delete ( e.g blue flag waypoints) and hit the enter button ( rocker on front unit). Good luck !
SOURCE: Unable to load coordinates for a projected waypoint
There are two ways you can load a way point.
1. Hit mark on your GPS. Push up on your rocker until the coordinates are highlighted. Once they are hit enter. From here you can change the coordinates to what ever you want.
2. If you have the software (Mapsource Trip & Waypoint Manager) you can enter the waypoint by going to "Edit" then "New Waypoint" or hit Ctrl + W as a shortcut. Once you create all the points you need, plug in your GPS and turn it on, then click "Send to Device"
Make sure that your mapsource and GPS are both setup on the same datum and lat/lon style corrdinates as well or it could throw it off.
SOURCE: my garmin says that its memory is full when you
Generally you remove all those places you have saved as a recent address
