Hitachi 60EX01B 60" Rear Projection Television Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv screen goes black and says string to test text mode?
I keep getting a black screen on my television with white letters that say this is a string to test text mode start up message function. What can I do?
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on Jun 03, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407303
Points
3279
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Black box appears on tv screen then disappears. sometimes the box has letters in it. it last for a few seconds then it goes away
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
1helpful
I get a black box that takes up half the screen and it puts random letters and symbols all over the box. it only happens on certain channels also. only on channel 17 and 7 and sometimes on 65
Look for the CC/Text button on the remote. The TV is in the TEXT mode and is showing garbage that is being sent by the broadcaster, You need to turn the CC/TEXT mode off.
8helpful
2answers
This is a string to test text mode problem
tienes activado la funcion de subtitulos debes desactivarla
2helpful
Square box in middle of t.v. black everywhere else.
Turn off the closed-captioning. If it's set for text mode, the screen will blank out an area for the text to be displayed. On channels or programs where captions aren't being used you won't see any problems, but other times you'll have the mysterious black box. Many TV remotes have a single button to control captions, so it's easy to get into text mode without knowing it.
1helpful
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
2answers
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
2answers
Black Message Window
have a tech take out the eeprom and change it for a new one.this will solve your problem.good luck.
1helpful
String test
Possibly the closed caption feature on this set has been turned on. There is a button on the remote control that says Caption. Press it until you turn the caption off. This will not be on a universal remote, only the original remote. You can also turn this off through the caption section on your on-screen menu.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
