SOURCE: I have an urgent issue of needing to display date Lumix DMC-FZ50
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ50K for pdf version of manual. The K or S means the color of camera you have...black or silver. My wife has that camera, there is no way to display the date/time on the pictures themselves, you will have to look at the properties of the image. All images now contain certain data that is hard for the novice to change and might be able to be used in certain courts...good luck, hope it's not too late.
SOURCE: I just need a user's manual for a Panasonic Lumix DMC-ZS3.
Go here:
http://www.dphotojournal.com/panasonic-lumix-dmc-tz7-zs3-review-samples-user-manual/
And click on the "manual" tab.
In reality, this is trivial to find, if you just type into google:
Panasonic DMC-ZS3 Manual PDF
It pops almost to the top. Probably would have been less effort than putting the question up here ;)
SOURCE: My Panasonic Lumix® DMC-ZS3 will not focus
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
SOURCE: I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
