Samsung 55 inch UA55ES8000 Smart 3D LED Mutlisystem TV 110 220 Volts Logo
L
Lawrence van Wyk Posted on Jan 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hdmi ports not working
Lightning last night hit my house,now none of the 3 hdmi ports are working, even if the bd player or the dstv pr is connected the tv does not pick the devices up
Artie
Level 2:
Champion:
New Friend:
  • Expert 236 Answers
  • Posted on Mar 11, 2014
Artie
Expert
Level 2:
Champion:
New Friend:
Answers
236
Questions
0
Helped
56464
Points
309
Disconnect EVERYTHING for a few minutes - reconnect and restore all factory settings.
Aim 60 Inch Digital UHD. There is no sound from my dstv HDMI connection only, picture is fine, decoder tested by dstv fine, other HDMI inputs work fine, I know the HDMI cables are fine. please assist.
If you're not getting any sound from your DSTV decoder when connected to your Aim 60 Inch Digital UHD TV via HDMI, there are a few things you can try:
  1. Check your TV settings: Make sure that your TV's audio settings are set correctly. Check that the volume is turned up and that the TV speakers are not muted or turned off. Also, make sure that the TV is set to receive audio through the HDMI input.
  2. Check your DSTV settings: Make sure that your DSTV decoder is set to output audio through the HDMI connection. You can usually check this in the settings menu on the decoder.
  3. Try a different HDMI input: If you have other HDMI inputs on your TV, try connecting the DSTV decoder to a different one to see if the problem persists. This will help to narrow down whether the issue is with the HDMI input on your TV or with the DSTV decoder.
  4. Try a different HDMI cable: Even if you think your HDMI cable is fine, it's possible that there is an issue with it that is causing the sound problem. Try a different HDMI cable to see if that resolves the issue.
If none of these steps solve the issue, it's possible that there is a problem with the HDMI input on your TV. In that case, you may need to contact Aim customer support for further assistance or consider bringing the TV to a repair shop.
4helpful
2answers
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
2answers
Panasonic Plasma TH-42PZ80U HDMI do not work after lightning storm
I don't have a solution, unfortunately, but your problem is nearly identical to mine. It even seems to have happened on the same date (7/27/12)! Do you live near Dener by chance? Anyway, we have Direct Tv, and ended up with 2 fried HD DVR boxes and 2 TVs on which the HDMI connections don't work after lightning hit close to our house on 7/27. Those boxes were replaced, as was part of the Direct TV dish. The only difference is, whereas on one TV component connections (red/white/yellow cables) allowed the TV to work normally, on the other (my 50 inch Panasonic Plasma TCP50S30) even the red/white/yellow cables did not work. Now I'm scouting the net for tips on what else to try before I possibly have the Panasonic looked at, which I am hedging on doing since I got it for only $600 new in the first place. Have you found out anything else since you posted this? Good luck to you...
1helpful
I have a vizio 55 in. e550vl the hdmi ports quit working when lightning hit a tree by the house i think maybe a surge came through the satellite if i was to replace the main board would that fix it i...
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
Can a sharp Aquos bd player be hooked up to a cable box using the HDMI cable
Can I ask why?
If it's only a BD player only, there is no reason for connecting it to your cable box - with HDMI or any other type of cable. It simply needs to be connected directly to your TV for playback.
If it's a Blu-ray (or DVD) recorder, it can only be connected to the cable box with HDMI if the cable box has a spare HDMI OUT port and the BD recorder has an HDMI IN port.
If you want to connect the BD player to the cable box for playback on your TV via the cable box, then the cable box would need an HDMI IN port, which it's unlikely to have.
Hope this helps. If you need further assistance, please provide model numbers of your equipment and explain why you need to connect the BD player to your cable box.
Regards, BElectric
My HDMI connection does not work with Blu Ray DVD player. I have tried a Sony (BDP - BX2 ) model and Samsung (BD-P1590). It could not even display the Home screen for the Sony. The Samsung played for 1 day...
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
4helpful
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
