WRT65G is opne of the old routers. You do not need to use installation CD or installation program to install this router.
you can do it manually also.
Here is link which will help you install this router manually.
https://fixhomenetwork.com/blog/linksys-wrt54g-router-setup/
You could install the Linksys WRT54GS without any CD.
You could use the Linksys EasyLink Advisor to scan your network for the Linksys WRT54GS.
The Default IP-address is 192.168.1.1 so you should be able to connect to the Linksys with your Webbrowser when you do a factory reset of the Linksys.
