Question about Ricoh Aficio CL7200 Laser Printer
Error code SC375 on ricoh cl 7200 - Ricoh Aficio CL7200 Laser Printer
2 Suggested Answers
Anonymous
SOURCE: ricoh cl 7200 error code 374
The code may go away if you power on/off, but it will continue to return. It is a problem with the black development unit - replace it.
* please rate me :)
Posted on Mar 25, 2009
gggg
  • 904 Answers
SOURCE: On the Ricoh CL 7200 there is an error code sc386....
sc386 = an error with the black developer. This could be caused by something in the DV unit itself, or the black toner. If you've just replaced either one of these recently, try reinstalling them and resetting the machine. Otherwise, the black development unit probably needs to be replaced.
Posted on May 28, 2010
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
How difficult is it to replace a fuser unit on a ricoh cl 7200? Do I need to pay a tech $140/hr to replace it - or is it fairly simple?
This has got to be the easiest fuser I have ever replaced! While facing the front of the machine, open the left side - it should slide out. Then open the upper handle, it will swing down. The item sitting there withe the green handle is the fuser. Just lift the fuser out. Installation is the reverse. There are no wires or connectors to mess with!.
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
On the Ricoh cl 7200 there is an error code sc386. What is it?
May 20, 2010 | Ricoh Aficio CL7000 Laser Printer
Ricoh Cl 7200 Black PCU says replace soon. haow many more copies can I make before the printer shuts down?
The black PCU sets up color registration, it is not that much. Do yourself a favor and replace. -Carl
May 14, 2010 | Ricoh Aficio CL7200 Laser Printer
Sc240 error code on a Ricoh spc411dn
SC240 = DB error [K]
[Symptom] The EGB detects LDB error a few times consecutively when LDB unit turns on after LDB initialisation.
[Cause/Required Action]
• Defective LDB
1. Replace the LDB.
Taken from: http://intranet.rjyoung.com/Service/Service%20CDs/printer/CL%204000DN/cl4000%20service%20manual.pdf
Mar 31, 2010 | Ricoh Aficio SP C411DN Laser Printer
RIcoh CL 7000 having problem within the copier, it's locked and unable to use WHat should i do
Most likely if you have no error code displayed then one of the hard drives is bad.
Feb 07, 2010 | Ricoh Aficio 450 Copier
We have a CL7000 which comes up with error message SC375 & SC387. What does these relate to.
sc 375= Vt error [Yellow] (toner density sensor error)
sc 387=Development gamma error Yellow
it looks like there is a problem with your yellow development unit.
it may not set in properly or needs to be replaced.
Jan 15, 2010 | Ricoh Aficio CL7000 Laser Printer
Ricoh cl 7200 error code 374
* please rate me :)
Mar 25, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio CL7200 Laser Printer Logo
75 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
