I tookit apart and cleaned everything out as well as changed the belt. Also cleaned filters. Will work for about 5 mins then overheats and wont work for awhile.
SOURCE: How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
SOURCE: Overheating Hoover
Most likely caused by a lack of airflow. Check to see if you have airflow at the end of the hose. If not, Remove all of the hoses and ensure that they are not clogged. If there is airflow through the hose; check the air inlet immediately aft of the brushroll, inside the nozzle. This is a very common place for clogs to form.
Also note: contrary to some manufacturers claims, you can not clean (or wash, for that matter;) a hepa filter. The small particles are too embedded in the filter media to ever get completely removed, and the act of cleaning tends to damage the filters, even if you can't see the damage. This is why bagless life-spans, on average, are half the length of the life-spans of bagged vacuums.
Good luck,
-R
SOURCE: hoover eite rewind vacuum has blocked airflow, how do i fix?
i had the same issue, but with a little time and a screwdriver, i got my vacuum working like new.
First, remove the bottom cover where the brush is located. Once the cover is off you'll see the vacuum inlet hose just behind the brush. Clear out any debris you find in there.
Second, on the back of the unit, where the attachment hose connects to the vacuum remove the three screws and clean out any debris you see in there. (dont be afraid to get your hands dirty)
hope this helps!
Country Music Guy
SOURCE: Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
SOURCE: My hoover elite rewind is making a louder noise
the smell is either the motor or the belt, if motor hope it is under warranty, if belt make sure brush roll spins freely and replace belt, if brush roll not spin freely replace it first
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1.
Press on the tab located on the side of the filter cover to remove.
2.
Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
