Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now living in Australia. Shouldn't digital tv's work everywhere?
ive taken the tv apart and trying to replace the 19 bulbs. where do i find the bulbs?ive taken the tv apart and trying to replace the 19 bulbs. where do i find the bulbs?
AnonymousMar 30, 2014
tesco tv has not complete channel scanning. some of channels are tune in channel tuning?. the countary is pakistan here connect tv.tesco tv has not complete channel scanning. some of channels are tune in channel tuning?. the countary is pakistan here connect tv.
You can't post conmments that contain an email address.
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
Use the arrow buttons to navigate to the channel setup or tuning menu
Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
if your tv is already receiving digital stations the it will receive 7 flix
If you are already using a set top box it will get 7 flix and all the channel 9 station as well
all you have to do is use the remote to get the on screen menu up, (press the menu button) --navigate around until you get the auto tune in channel selection auto or manual---select auto tune and let it go and all the extra channels will be programmed in
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
? 25:30
https://www.youtube.com/watch?v=IxKcCbjLD4I
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
should have to do with the re reprogramming get your manual and try to reprogram the channels such as cable or tv or cable tv or dtv just make sure you choose the one with cable and dtv
Sounds like the digital tuner modual has failed. Check all connections into the TV and make sure secure. Check with another Tv at that location & make sure you have signal. If all checks out with signal & runnning auto program, then you have a faulty tuner.
I have the same TV and was unable to get the digital channels until today. I think you need to connect your antenna on the back of the TV to the ATSC jack. If you have had it connected to the VHF/UHF jack, it won't detect the digital signals. Once you have the antenna connected to the ATSC jack just Auto Program your TV and you'll find all the digital channels in your area. Good luck!
Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
Press the BLUE button to display the MAIN MENU.
Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
Press the RED button to start the auto tuning process for all available digital channels.
Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time. You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information http://www.freeview.co.uk/_retuneinfo/
