SOURCE: ricoh cl 7200 error code 374
The code may go away if you power on/off, but it will continue to return. It is a problem with the black development unit - replace it.
* please rate me :)
SOURCE: sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
SOURCE: On the Ricoh CL 7200 there is an error code sc386....
sc386 = an error with the black developer. This could be caused by something in the DV unit itself, or the black toner. If you've just replaced either one of these recently, try reinstalling them and resetting the machine. Otherwise, the black development unit probably needs to be replaced.
