SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
SOURCE: time changing on fossil jr9120
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
