I never set up an Administrator Password, so I left that field blank, as instructed. But, it said the password was incorrect. I then went down the "forgot password" flow. When I tried to save the password, I received the following message: "Unable to reset the QuickBooks Administrator password at this time."
Resetting QuickBooks Admin Password
On your QuickBooks login screen, click Forgot Password.
Fill out all the information on the form. Then, select OK.
You'll receive a code through email. Enter the code. Then, hit OK.
QuickBooks will then guide you through creating a new admin password.
This May Work,,
Peter
QuickBooks Automated Password Reset Tool
Have you lost or forgotten your administrator password?
http://support.quickbooks.intuit.com/support/PasswordRemoval.aspx
for more hlep visit
http://www.techsupportquickbooks.com/quickbooks/quickbooks-technical-support.html
SOURCE: Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
SOURCE: Setting up Email Preferences for My Mail List and Postage Saver
READ THIS....http://mail.google.com/support/bin/topic.py?topic=12883...FORWARDING N POP SETTINGS IN GMAIL.You must also tell gmail to load pop/forwarding settings confused or need more help contact me.RICHARDM69
SOURCE: VERSACHECK
You need the following file from the G7 web site. http://www.versacheck.com/update/2002/vcheck7_0_9_1.exe .Follow instructions carefully and Versacheck 2002 will run.
SOURCE: "unable to read file" message when opening an Excel workbook.
Okay those of you that is having this issue try reinstalling the Ms office software along with any emulation program you have on you mac.. this will shore up alot of problems that can reside from coruption. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: How I bypass the login for Quickbooks 2002, wasn't there before.
Contact Intuit, they will supply you with a reset application that can be used to reset the password. They've done it a few times for me in the past. You'll need to answer their questions (of which they have many) and it might cost you something, but I know for the situations I've had to use it in the past, it was certainly worth a few bucks to get into the books!
Hope this helps!
