SOURCE: drum error
With that error you need to remove the drum, run the little blue tab on top back and forth about 20 times, blow out the area below the blue tab, and re install and try printing again. If the error is drum life end you need to open the front door and press either menu or options, sometimes the clear/back button and tell it it's a new drum.
SOURCE: PRINT UNABLE 46 SEE TROUBLE SHOOTING CHAPTER IN
i posted few days back solution to this particular problem, please follow these steps:
first, try to establish if this really is full absorbent pad, remove
power cable from the back, wait 20sec, press menu/set key, insert power
mains - in most brother printer/faxes this will display machine error
code. if this is code 46, you are on the money, your absorbent pad is
full (not necessarily, only counter is showing it as such in most
cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if
that do not work, then maybe really you need to replace absorbent
sponge... it is done under warranty and if not technician in service
centre.
if you want to do it yourself, remove cartridges, remove
fron cover and on the right hand you will have "offending" sponge.
either clean it (absorbent, lint free tissue is fine to remove excess
first, then few drop of water and repeat draining process with tissue
several time, at least till "cake" from the top is removed. best of
course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
if you find this advice useful, pleasae leave comment and rate it, thanx!
SOURCE: see troubleshooting and routine maintenance
Error 46 in my printer brother DCP-165-C any help please
SOURCE: unable to clean see troubleshooting and routine
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
