Question about ASUS RTG32 Router
Asus RT-G32 Wireless Router Firmware 3.0.2.1
After upgrading the firmaware of RT-G32 i am unable to connect to the internet via my modem.When i check using the ipconfig/all i can see the ip address assigned to wireless lan and also the gateway is there.But when i ping yahoo.com from command prompt my laptop is not able to resolve the DNS.In fact i am not able to ping the DNS ip from coomand prompt. Internet is working fine if i connect directly to isp modem.
5 Suggested Answers
6ya staff
SOURCE:
shubhu33
SOURCE: Hi I am using ASUS router
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
thx
shubham
shubhamformeATgmail.com
Posted on Feb 09, 2011
Benjamin Jr Singson
  • 1570 Answers
SOURCE: We have just bought an
Hi
You have to get the IP address of your internet service provide and once you type this IP address to the address bar. It will go you to menu set up of the router and set it up there. The encode the new password set up.
Posted on Feb 27, 2011
vgare
vgare
  • 17 Answers
SOURCE: Hi, I have got RTG32 router
Do you use a username and password provided by your ISP on the computer to connect to the internet? If yes, these need to be entered into the connection settings of the router. Are you connecting the internet line to the WAN port on the router? Did you install to your computer the ASUS utilities? Try the EZ Setup utility. You can download the manual from this link http://www.asus.com/product.aspx?P_ID=gEbdYWdf5mjkJUKc
Posted on Mar 09, 2011
tomba_nzxt
Tomislav Marinovic
  • 205 Answers
SOURCE: i do not want wireless router to assign ip addresses for lan
not sure if you are doing it right
your wireless router has 2 "sides" one is it's upload, it's wan network and that is where you should set DHCP - so that the router itself gets an ip from your LAN
other side is behind your wireless router and there DHCP should also be off. it would be best if you could put your router in bridged mode - just to extend your network over WIFI
Posted on Mar 09, 2012
I have Asus RT-G32 and it works max 10 mbits. How can I change it's speed to 54G
its your ISP that limits you. you probably have a 54G connection between you and your router and a 10mbits connection to the internet. so, when you run a speedt test you show 10mbits...
your service is working fine...
and FYI: when you do a download and it says your downloading at 56k or something that has nothing to do with you or your ISP, thats how fast the person hosting the file can send it to you.
yup, the internet is one bottle neck after another!
Nov 14, 2013 | ASUS RTG32 Router
Hi, I have got RTG32 router installed for a small business (5-6 ) machines .From machines I can see and update router settings but I can't see internet line working from router. Internet is working...
Mar 09, 2011 | ASUS RTG32 Router
When i try connecting my ASUS wireless router model no: RT-G32, it is asking for network key
try reinstalling the router then it would ask you for a new network key
Feb 14, 2011 | ASUS RTG32 Router
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
thx
shubham
Aug 14, 2010 | ASUS RTG32 Router
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect via wireless network, router not being detected by laptop or ps3. I can connect to internet on desktop via modem through router. When trying to detect wireless network via laptop and ps3...
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Aug 14, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
CanĀ“t access 192.168.1.1 (router admin page)
hello!
-- who is your internet service provider
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Apr 19, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS RTG32 Router Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
