SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
SOURCE: ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of
the machine. If the tank is full, check the tubes, oil pump, and oil
sensor.
Reboot the machine to clear the SC.
The problem will be solved
SOURCE: What is SC305 Error Message - Ricoh 1232C On
I worked on this same code just the other day for a customer. This SC305 code means the charge corona cleaner is not working properly. The charge corona is located behind the large front door, towards the bottom and just left of center. It has a small thumb screw and a white cord with an end on it like a telephone cord. You can try removing the assembly and blow it out carefully with canned air. Be careful about the very thin hairlike wire in the shell. You can also remove the end of the unit and check that the motor is not gummed up. If it is just put a little light oil on it. Just cycle the power off then on again to reset and try.
Usually once they get repositioned properly they will work fine. Sometimes I have replaced the unit with one from a parts machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
