I have a French door model with water and ice dispenser through the door.
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
SOURCE: Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
SOURCE: I have a Frigidaire Model#
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
