Please help guys Canon IR2520 giving me a beep and error 853 on the panel when trying to print. just added 2 new computers and it does the same on each. plz help
Is there something left left that's supposed to be done after adding a new client (pc). Communication is there, but the printer just warms up and makes a beep then nothing comes out. when i check the jobs log on the printer panel, i see "Result NG853"
  • Office Equip... Master
  • 18,165 Answers
There are only two things that could cause this. Only one applies to you. That one is the printer driver, Make sure that you have the right one installed.
Posted on Jan 27, 2014
Anonymous
SOURCE:
Anonymous
  • 7 Answers
SOURCE: Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
Anonymous
SOURCE: Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Posted on Jan 24, 2009
Anonymous
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Posted on Feb 05, 2009
Anonymous
  • 90 Answers
SOURCE: hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Posted on Jun 22, 2009
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Posted on Oct 29, 2009
How do I change my wife's email user name?
Here is Microsoft forum on the error code
Windows mail error code 0x800ccc90
Cause for this error is generally The client is trying to use Secure Password Authentication and it is not enabled on the Exchange Server computer. To verify what form of authentication the Outlook Express client is using, in Outlook Express, on the Tools menu, click Accounts, and click the Server tab for the account that failed.
Also when your adding the 19 to the email it is creating a whole new email. So if you created the new email. then please refer to this link
POP3 Outlook Express error 0x8000CCC18 and Exchange Server
Aug 10, 2014 | Microsoft Outlook Express
I have a samsung scx 4623fw, im trying to scan something on to my pc, i put the paper where it is supposed to go, make sure my computer is connected to my pc, which it is. and i go press the scan button...
The communication between the computer and the printer have disconnected. Do a reset of the printer. Rest the parameters, like the IP Address, Pass Codes, etc.
Check you DEVICES (Printers) to see if it is sending a Wi-Fi signal?
Jan 31, 2018 | Samsung SCX4623F Laser All-in-One Printer
When i try to open my mail box it shows application not found
Do you have an e-mail client installed? If it was, then something told the operating system to disassociate e-mails from that application. If you don't have an e-mail client installed, then pick one (Outlook, Thunderbird, old Navigator, and many others) and install it. But make sure the operating system associates your e-mail files with your new client. In Windows, the icon should change to something like an envelope. MacOS has something similar.
In Windows, you have two options to reestablish the link between e-mail files and the client.
#1. place your mouse over the e-mail file, then press the right mouse button (or which ever is NOT the normal selection button). Look for a drop down menu option that says "Open with ..." which should show you a list of installed applications. Your e-mail client should be in that list. If not, then click the "Browse" button (lower left section), and find your original e-mail client program.
#2. Start your e-mail client (should still be in the START-->All menu (or sub) somewhere). It will probably ask if you want it to become the default for all e-mails. If not, go to Preferences (usually under Tools, but might be under Edit), and (usually) Advanced tab/listing, and find something that says "make XXX (program name) the default...", and then save the new setting.
Good luck. (Since you didn't provide the operating system name or possible installed e-mail client)
Feb 19, 2011 | Computers & Internet
Cant get it to install ,everything is checked but wil scan and print but no communacation with pc
Hi, First Identify the communication cable type, connect it to the communication port for the printer and the PC. when this is done, power on the printer and the PC, bear in mind that you must have the OEM drivers for the printer with respect to your Operating System.
The System will automatically find the new hardware and it will identify the exact,and it will request for the OEM drivers, please feed it with it, and follow all other necessary instructions, and you are done.
Regards,
Apr 22, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
When i print something on my comp., my printer
halo!!! try to uninstol or remove the printer driver din install it again.how to do? ans: go to the start, and find the control panel din click the ad and remove program fin the printer driver and uninstal it
Jul 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error:SSG_THNK-32 Diag/Eerr(9)
create new user and your problem is solved
descomp_7@yahoo.com
Jun 24, 2009 | Office Equipment & Supplies
Can't print from shared printer
Did you connect the printer directly to the laptop to install the drivers? If so, you need to change the port to the network location to //hostcomputer/printer. You should also have the same user name and password set on both machines and have the user rights assigned to the printer sharing.
Jan 24, 2009 | Epson Stylus RX500 All-In-One InkJet...
Lexmark Z645 Printer
i have a problem of Lexmark Z645 Printer i want a software of this .
Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
5,062 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
