Mp c 3500 ricoh
SOURCE: 9040 waste tone full message
for the 9040, there is a tech bulletin for a new style contact harness for the transfer unit. this should solve your problem.
SOURCE: Ricoh MP 3500
Ricoh is having a major problem with touch screens on a lot of the newer machines. Contact a dealer to see if yours is one of them and for replacement.
SOURCE: our ricoh aficia mp 3500 states close lid but it
Try opening and closing it again, just to make sure. If it is not sitting exactly right, the sensor may not be actuating.
If that doesn't help, open the lid and look for the cover set sensor. It will most likely be a small black sensor with two rectangular tower-looking sides, and a plastic actuator on the lid will fit right into the space in between the sides when the lid is closed. Blow some compressed air onto the sensor to get rid of any dirt or debris that may have accumulated there.
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
