Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
A
Anonymous Posted on Jan 27, 2014
Maytag wall oven is non-responsive after power outage.
We had a power outage, and now the oven is totally non-responsive. Is this due to the Sabbath Mode?
4 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jun 13, 2008
SOURCE: Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Anonymous
  • Posted on Mar 08, 2009
SOURCE: Need to unlock Sabbath mode
I have a Crosley gas oven and I had the same problem. According to my manuel it will shut off automatically after 72 hours OR Press the CLOCK pad for 5 seconds - no beep will sound. The Sab will flash and then the time will be displayed.
I hope this helps.
Anonymous
  • 3361 Answers
  • Posted on Mar 14, 2009
SOURCE: Sabbath display makes oven inoperable
Hold the clock button "in" for 5 seconds to disable Sabbath mode.
Anonymous
  • 2341 Answers
  • Posted on Oct 13, 2011
SOURCE: my maytag gemini oven has been stuck in sabbath
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
Skip,
The fact that the display is 'ON' confirms you have power.
The displayed info probably is a 'code' for a fault/problem, but you did not provide a brand nor a model. Even if you had, odds are I do not have access to the list of codes & their meanings.
Try unplugging the plug from the wall receptacle. If you cannot reach the power cord next option would be locate the circuit breaker (single pole) which HOPEFULLY is labeled. Either way, try removing / turning OFF power for at least 10-20 seconds! The control's microprocessor may be locked up due to a very short power interruption.
If that does not reset it, I would call service or the manufacture. You can TRY requesting help over the phone FIRST! Good LUCK
Mrs. Robin Adair-Weber, CET
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
Or
NOTES:
GENE
2helpful
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
17helpful
3answers
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
1helpful
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
