WANT TO SWAP BATTERIES WHILE IN THE FIELD.A HOT SWAP.TAKING PICTURES AND BATTERY GOES DEAD. SWAP IT OUT WITH A FULLY CHARGED ONE WHICH YOU CARRY.CAN DO?
Hi
The Droid RAZR M is a non-removable battery device.And if you try to remove it, it is consider physical damage.
Please contact us to check your repair options. Motorola Support Find Answers Motorola Mobility Inc
Regards
Marge
Motorola Mobility
it probably needs to be reset by taking the battery out for a few minutes or you can try checking to see if there are any software updates for the phone
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Ignore some of these my gently pop the back. Off thru the seam. U can do it with your nails. It's glued to the batter so. Use something like a. Butter knife and work it down thru but pushing up not. Down. You don't wanna puncture battery. Separate it from the battery. Then remove. The red. Rubber protector. Over the two. Screws St the. Bottom. Left I. Think. It is. Remove screws then use the tab that says pull to remove or whatever be careful. Not to tear the flex cable.... Those batteries aren't cheap
Remove the battery. Hold the power key down for 30 seconds while battery is out of phone. Replace battery, and turn on the phone. Problem should be solved.
