Where is it located?
SOURCE: BROTHER MFC 210C INK ABSORBENT BOX
You can order the part directly from Brother ( ph # 1-800-284-4329). The part is called an "Ink Absorber Box Assy" . The part number is LF7544001 for a MFC-210C printer. It cost about $11 and shipping is about $5. There is a website that has different diagrams for various brother printers. You will also see part numbers.
SOURCE: Waist ink absorber box
When you have purged , cleaned the print heads, your Brother Printer
about 6,450 times it will be unable to print anymore. This is because
they recommend that the printer is serviced this will cost you up to
£120 (not bad for a printer that costs £60 NOT!!!)
The simple
way is to spend £25 and buy your own replacement pads if you are up to
taking the printer apart, see service manual this is hard to get hold
of as are these instructions !!!!
In the mean time you can RESET
this purge count back to zero using the MAINTENANCE 80 menu, to
continue using the printer for a while until you get the new pads. But
it on a tray as if they are full they may start to leak onto your
desk....
1 . Press (MENU) (MONO START) then (^) OR <the up
arrow> four times, the Photo Capture and Red Exclamation Lights will
then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4.
Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess
this means you have cleaned the heads over 6,450 times their threshold
level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
You can also RESET using the <2783> If you press the wrong key you will see MACHINE ERROR 46 on the LCD.
INK_CH BK Number of Black Cartridge changes
JAMS Number of paper Jams
PAGE Number of pages printed
PC Purge Count over 10,600 will cause stop
COLOURCOPY Number of Colour copies made
MONOCOPY Number of B&W copies made
MEDIA ......media....
FAX Number of Faxes sent
PURGE Numbe of Purges, head cleans
POWER Powered Up Hours
