SOURCE: ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
SOURCE: ice and water dispenser for Maytag H20 not working
Ice 2 0 ...lights flashing and ice door flapping... i called 1-800-4maytag like someone else suggested.. they are sending me new high voltage board for free..and they will install it for free.. even though it is 2yrs old.. for once someone stands behind there product..
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
