Emerson LC320EM9 32 in. LCD HDTV Logo
A
Anonymous Posted on Feb 03, 2018
Does anyone know how to turn off the power-saving feature on Emerson TVs? My TV keeps shutting down in the middle of the night, etc., and I don't want it to.
I'm not sure if this is the exact model but it seems to look the same, and from my experience, they operate nearly the same. I can't seem to find a way to turn off this auto-shut down feature. I'd like my TV to stay on, but it shuts itself off after what it assumes to be periods of inactivity.
Nhlapho Paul
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 03, 2018
Nhlapho Paul
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
2951
Points
37
5 Related Answers
Anonymous
  • Posted on Nov 24, 2008
SOURCE: my emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Anonymous
  • Posted on Jun 18, 2009
SOURCE: Emerson tv shut itself off
cannot turn on
Anonymous
  • 6 Answers
  • Posted on Jun 19, 2009
SOURCE: Emerson rv LC320EM9 3 just shut itself off and
I've been working on Televisions since 1975. I have unfortunily had experience with this model 4 times in the last 2 months. The problem is the same in all sets. First off it is made by Funai in Malaysia and that should tell you the whole story. All the sets that have come through this shop are in the dumpster now. This BLC320EM9 is made just for Wally World and you cann't get parts for them due to a contract between Funai and Wal-Mart. I'm affraid this is just the beginning of your headaches with this set. It has a multitude of other problems... Wish I could have brought you better news. Dan@DBS
Anonymous
  • Posted on Jul 21, 2009
SOURCE: Emerson EWL20S5C Shuts off after 10 secs
http://www.hypercubetech.com/EWL20S5_shutting_off_problem/index.html
Anonymous
  • 608 Answers
  • Posted on Dec 09, 2010
SOURCE: I have an Emerson TV Model #LC320EM9B about 1
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
2answers
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
My tv keeps turning off
Return that TV as soon as possible. Don't waste your time trying to fix it You get what you pay for in LCD TVs.
I turned Emerson tv off last night and so far have sound this morning - is that the norm
If it is still under warranty, take it in for service. There is a problem with the micro-controller on the main board or the power supply control circuit. It is not working normally!
My Sony Wega, model# KDF-E60A20 keeps shutting off for minutes at a time. The green power light stays on , no flashing. A few seconds before it turns back on ther is a click and a power up sound. Does...
Just replace the bulb first. They last a long time, but after a while if they don't simply blow, they will start to shut off for short periods, then restart. The odd thing is the whole set shuts down too, so something else also may be happening, maybe to do with the temperature control circuitry, that causes a full system shut down. My TV repair man said try this first before I bring the unit in for a diagnostic. Transporting them is not an easy thing to do, given the size of these TVs. I originally bought 3 extra bulbs in 2005, and now used up the last one, and I use the TV a lot.
1helpful
First tv kept tuning on in middle of night now its kepts tuning off while ur watching
I don't know what might have been making it turn on in the middle of the night. It it keeps turning off while you are watching, you might want to check if:
1) someone is accidentially hitting the SLEEP button on the remote. The TV will turn off automatically 30, 60 or 90 minutes after the sleep button is hit. It can also get hit if you set the remote between seat cushions on the couch and someone moves, etc.
2) Does the TV get enough ventilation to allow heat in the TV to circulate away from the set? Drapes, tight cabinet, etc. The temperature sensor may turn the TV off automatically to protect the TV.
3) Your power cord is not well plugged into the wall or you might have some issues with the wall outlet - expecially if it is an older home (before 1980). Any wiggle of the cord may cause it to disconnect for a very short time - the TV will shut off.
4) This Brand is only available through BEST BUY and this model has a 1-year warrentee. The manual says to call 1-888-BESTBUY for service.
Good luck.
Please rate me.
5answers
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
1helpful
Emerson TC1351 Chassis Power Switch
As cheap as 13inch tvs are why do you wont to fix it , I sell nice used 13inchs for 40.00
12helpful
6answers
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
TV pops and shuts down
Get a good fire insurance policy!! The problem you have is the flyback transformer but its going to be hard to get just that so order the sweep board that the transformer sits on. Also your making a very dangerous situation for you or your family. Im praying something doesnt go bad in the middle of the night and start the set on fire. As theres always power to that set. Good luck and dont risk your life or anyone elses to save a few bucks. Get a trained tech to service this set, as a TV set is no place for an experimenter to be. Good Luck
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
