Question about Comfort-Aire BHD-501 Dehumidifier
It stopped working
Stucked at humidity 70 wont go up or down,unit won't work, tried unplugging it when it restarted made a noise for 5 minutes than shut off
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Rapid cycling
The has been no solution offered, just as there was no solution for the individual who had a similar problem and posted in Nov 2006. The only offer is to purchase a solution which I have determined is the only function of this website!
Posted on Apr 02, 2008
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
Goes on.... humidity % registers 70 but in just a minute or 2 it begis to decline and ends up at Lo which then wont pull water from the air. I know it is humid, some sensor must be getting fouled up.
70% is not what the dehumidifier is removing. It's what it is maintaining. Which is extremely high humidity. To lower the humidity level in the house lower it to 35%. That will remove a large amount of humidity over a fairly short (4 hours) period of time. If you have an analog unit (no LED Screen) set the humidity extraction knob on Maximum, which is 35%.
Keep in mind, dehumidifiers work the opposite of what you think.
Hope this helped you and thanks for choosing FixYa..
Sep 16, 2011 | Dehumidifiers
I have an LG model LHD65EBL dehumidifier. The humidistat will not change from 70 when I push either + or -. The fan runs well and the compressor sounds like it is running well Some water comes out when the...
Prt of the problem may be a dirty or clogged air intake filter.
Turn the unit OFF and unplug, it before removing the filter to check and clean it.
You can ether vacuum it or if it's really dirty & clogged, wash it in warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow it to dry completely, before reinstalling it.
Never operate the unit without the filter in place. As this could damage the unit.
Plug the unit back in and turn it ON. Try lowering the humidity extraction level now, using the arrow down button. For a very damp, humid basement application 35% is a good setting to start with for several days.
Sep 08, 2011 | LG LHD65EBL Dehumidifier
I cannot change the set point on my humidity control. It is at 70%. If I press the up arrow i get 2 beeps and no change. When I press the down arrow there is no response at all. Is there some sort of...
The problem is, your trying to raise the humidity level, not lowering. These work in reverse of what you may think. Lower the level (Arrow Down) to 32% and it will continue to run, but will draw more humidity out of the air and will not stop until the water collection bucket is full or the humidity level reaches 32% or you turn it OFF.
When you pushed the Arrow Up Button, it was already on 70%, that's as high as it will go. But that means, you're trying to maintain a 70% humidity level. If it's Summer where you are, I don't think that's what you want.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Kenmore 54501 Dehumidifier
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
My dehumidifier is not working. The control panel lights-up, but its stuck on 70% humidity and won't adjust down. I took it apart and noticed burnt marks next to the circuit that controls the humidity....
I'd say you're right on target. In which case, although the unit was manufactured my Whirlpool for Sears under their house brand, Kenmore. You can find the part(s) online at Sears Parts Central
http://www.searspartsdirect.com/partsdirect/index.action . If you can do the replacement yourself, you'll really save $$ on labor.
May 30, 2011 | Kenmore 54701 Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I...
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
May 03, 2010 | Comfort-Aire HD-651 Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Comfort-Aire BHD-501 Dehumidifier Logo
54 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Bill Long
Michael Youngman
Michael Youngman
Tom Chichester
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
