SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
SOURCE: how do you remove the isofix base from the car
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
SOURCE: Can the isofix easyfix base
Good Afternoon
The yellow plastic IsoFix guides are for assistance only when fitting the unit and make no difference to the performance. If you are able to fit the base so the indicators go green it is fine to continue using without the guides. Alternatively if you need replacement guides they can be ordered via your retailer or direct from our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
