I don't know how my lyca registration failed? I want to Re.active my this sim
If your lyca sim card is failed to work in your cell phone then your phone is probably network locked. To unlock it,visit the site Unlock-Zone.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network sim card.
Unlock Zone Supported Phones
SOURCE: the phone keeps displaying sim card registration failed on phone
The sim card holder is too loose on a lot of new Nokia phones. Place some folded paper (3,4,5,6 times) between the sim card and the sim card holder. It should fix it. I have an E65 and had this problems for two days after buying it. Since I fixed it 3 months ago, never had this problem again. Hope it works for you too.
SOURCE: My SIM card is active in other phones but when i
try to insert another sim to your fon, then if it is not, the power IC has the problem
SOURCE: SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
