Freezers Logo
K
Kevin Jones Posted on Jan 29, 2014
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost coil does not ice up, defrost elemen is good, and can cause defrost tstat to open/close. Seems like defrost timer could be stuck in ON mode causing freezer to defrost every time defrost tstat closes and stop when defrost tstat opens, repeating this cycle continually. Food remains frozen. Is it logical defrost timer is the cause?
Jim Pidgeon
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Jan 29, 2014
Jim Pidgeon
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
4012
Points
29
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
  • Kevin Jones
    Kevin Jones Feb 09, 2014
    I have replaced the defrost timer. It seems to have helped but not sure. I still here freezer running more than I expected considering it is still between -10 - 20 deg F here. Guess the defrost cycle itself would cause the freezer to run some after defrost is complete. Not sure how to know if it is normal for unit to run as much as it is. If there is a problem, I think at this point it would have to be related to the refrig. system. Defrost tstat & element & door seals are good; freezer tstat & defrost timer have been replaced. Unit is 10 years old. Would cost more than worth to have refrigerant checked. Btw, defrost coils had no frost on them when I started troubleshooting problem - it's not a problem of unit NOT defrosting. I haven't checked for frost on coils between defrost cycles after changing defrost timer.
5 Related Answers
Ian
  • 51 Answers
  • Posted on Jul 25, 2007
SOURCE: Not cold enough?
re-gas required
Anonymous
  • 1314 Answers
  • Posted on Feb 20, 2008
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Anonymous
  • 150 Answers
  • Posted on Apr 23, 2008
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Anonymous
  • 555 Answers
  • Posted on Jul 21, 2008
SOURCE: Frigidaire Upright Freezer
The manual for this unit can be found here.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 27, 2008
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Ffu20fc6aw4
how old is your model you have. a weak pump will make the system slower to get to temp even a broken seal can do this. even just a few mil gap can make it do this. if you close the door then re-open it it should be harder to open the door. this is the seal being nice and tight to its fittings.
Jan 29, 2014 • Freezers
Is the freezer being outside causing motor problems
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
New freezer set on 4. Runs a lot. Could we raise setting safely.
Yes you can raise the setting if you'd like. The rule of thumb is to raise it one number and allow it to adjust for 24 hours to see a change in internal temperatures. Freezers can run more for several reasons. One is the amount of product inside- the more the merrier. More frozen food will hold the temperatures longer. Another common issue is location, my own freezer is located in the garage at my house and runs quite a bit in the summer, as the temperature outside increases the lenght and frequency of the freezer running will increase. Freezers transfer the heat they remove from inside the box to the outside of the box, so the warmer it is outside, the longer they have to run to do the job.
Also be sure to keep a good eye on this, keep a thermometer in it and make sure you are not having to turn it way up to get it to "0 f" at least, as you may have a sealed system problem. Real ice cream (not fat free or sherbert) is a great indicator of temperatures- at 0 degrees f. real ice cream is firm but scoopable, 5 below and it's pretty hard, 5 above and is't starting to get soft on the outside.
Hope this was helpful to you!
Jun 26, 2010 • Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
2helpful
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
