Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Product spec says "Support external 3G module dongle".
You need to find a compatible one, Kocaso don't do one.
Put in a SIM card, pay for a Data connection, every 30 days.
Set up the connection settings dependent on the SIM supplier.
This depends on where you live in the world.
Huawei E173 is the only one that someone has found to work on android tablet.
