Tablet is less than a month old and has significant battery charge, and in the middle of playing an everyday app game the tablet went into a white noise picture. I shut it off by holding the power button for a few minutes but now it doesn't come on, what should i do?
Re: Tablet is less than a month old and has significant...
Hold down power and volume up and down at the same time for 10 seconds and then release. should reboot. if not then there is something wrong with the board or a software glitch.
Walmart
Rating: 2.5 - 233 votes
Buy RCA 7" Tablet 8GB Quad Core at Walmart.com. ... RCA 7" Tablet 16GB Quad Core .... stereo headphone jack; 8GB onboard storage memory, additional memory via microSD card slot ... Due to federal restrictions, this item cannot be returned by mail..... A. You can save music on here and play games from the app store.
Walmart
Rating: 3.5 - 611 votes
Buy RCA 7" Tablet 4GB Memory at Walmart.com. ... read eBooks, view photos, play games, listen to music and watch video files. ... Cannot return by mail ... does not have a credit card and I do not want him to have permanent access to mine, ..... About Our Ads · Affiliate Program · Sponsorship Requests · CA Privacy Policy ...Missing: fb
? 5:11
https://www.youtube.com/watch?v=bNA2XaR_Yc0
Mar 22, 2014 - Uploaded by Underground Tech
Reviewed the newer version of the tablet and discussed BATTERY ISSUES: ... you can play Pokemon on here .... thistablet also cannot transfer files or cancel active downloads. those... Can the sd card extension actually hold apps on it? .... HP Envy 15.6" Laptop Gaming Performance [A10-5750M][AMD ...Missing: access fb
specify weather it is plugged in or not when this happens and if the battery is above 30%
if plugged in, is the plug getting loose if so replace the wire that charges it and plug will be tight again . clean around plug with folded paper corner to be sure nothing is inside pressed to back of plug slowly shorting power. batteries do wear out in these things so only plug back into charge when it is below 20% and let it charge all the way up. as each partial charge cost you one of the 1000 charges in the battery's life. get Battery Doctor from the play store it will trickle charge at end of cycle and will tell you the battery's health. good app.
Try deleting the app completely from your tablet, then reinstall it again. It should them work (Settings -> Apps -> "Slots" -> uninstall
Then go to Google Play and install it again.
I'm not familiar with this particular game, but this is a pretty standard approach to any misbehaving apps. NOTE you will probably lose any save data that went with the game, but at least it should be working again
Very gently unplug the battery
cable for two minutes. I used a pair of tweezers and worked it out.
Plugged it back in and it is fine. What a relief. I have read that if it
goes to sleep while plugged in via usb, it freezes? Don't know. Just be
careful when pulling the battery!
