Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony Bravia LCD TV stand by red light flashes 13times
We turn the tv on at wall, use the remote to switch on and the standby light turns on green, you hear a noise like when a cd or dvd loads then the standby light goes red and flashes 13 times a pause then it continues to flash 13 times.
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
    New Friend:
You shud contact the customer service centre...cuz thats what im doin..its really complicated for me to repair it on my own. they say it there might be a problem in the mother board o_O
Posted on Oct 25, 2012
    New Friend:
Same thing is happening to me, every time I call the repair people, the problems stops happening. sony isn't being so helpful either. its a $2400 TV that is 16 months old - (6 months past the waranty)
driving me nuts
Posted on Jan 15, 2010
  • 4 Answers
It sounds like a power supply problem sounds like its trying to boot and then its losing voltage somewhere the flashing lights red will be a series of flashes pointing to a certain fault.have you looked in the manual on faults.if not ring your tv helpline you should have a service no sorry cant help more if i find anything out ill post on here.
Posted on Jun 29, 2009
I have this same problem. turns out one of the CCFL bulbs in the panel is out. the entire panel needs to be replaced!
Posted on Aug 25, 2009
  • 643 Answers
Sounds like your main board or powersupply is faulty not worth repairing
Posted on Jun 04, 2009
6ya staff
SOURCE:
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
Standby light blinking
If you can't turn it on with the on button on the tv its not the remote causing issues. Are you able to pull the back off it and take some voltage measurement readings/
Dec 07, 2017 | Televison & Video
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
When i on the tv by remote the red standby light turns into green and i hear the tv sound but not picture and after a one or two second the green light turns into red. The tv goes into standby mode when i...
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Jul 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
4,686 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
