Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
have the radio checked out as the band change switch is not working. Try going into the mode /menu section of the radio and adjusting it there . Changing antenna does nothing as the radio works on either band with the same antenna
Hi ,On the unit and donot put usb or sf card unit will automatic catch fm radio,make your there is fm radio signal is there,if still fm cannot connect that mean unit is having problem,Then go to the seller,Where you bought this .Rgds Sonilex Team.(China )
Attach the wired headsets, because they will act as the FM antenna. Then, go to 'Menu > Entertainment > FM radio'. Once there, go to 'Options > Auto scan > Yes'. You can make it play through the speakerphone too, by going to 'Options > Listen via speaker'. You can also make it keep playing FM radio while you make other things with your phone, by going to 'Options > Play in Background'.
Hope it works for you.
Cheers!
Carlos
BOUGHT
MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST
INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE
OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING
IS PLAYING FROM RADIO
it cant be switched off all you can do is either you can change the track or else you can switch the whole player off by pressing the play button... thts the only way!
