Ricoh Aficio 1018 Printer
SOURCE: code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
SOURCE: ricoh aficio 1018 i need to reset 541 code. when i
when u reset phot/txt mode button must also be pressed with ok button. press both buttons together
SOURCE: I NEED Ricoh Aficio 1018 Printer/COPIER AND SCANNER DRIVER
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x1015_18/x1015_18en.htm
There you go M8!
Just selcet your OS and download the files you need
Good luck to you
If you find my answer helpfull, dont forget to vote
SOURCE: SC 541 on Ricoh AP410N
press "yellow key"->107->Press "Red Key"for 5 sec-> 5#810 -> Press"Text/Photo Key" and "#" at the same time.
Reboot machine.
