Question about Zeki Berk Ulu 8GB 7in WiFi Android Tablet - Black/White
My zeki tablet wont rotate when you turn it
In the locked screen and the videos on youtube it will tilt but on the home screen or in other apps it doesn't rotate
    Sergeant:
  • 314 Answers
Go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Posted on Mar 05, 2014
Anonymous
SOURCE:
Where is the reset button on a zeki windows tablet located at
Hi Brenda, The link below is a youtube video showing you how to fix your tablet, Also there's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 24, 2016 | Tablets & eReaders
I did a reset on my zeki 8 inch screen,now its stuck on the main meep tablet screen,can you help?
Hi Trisha, The link below is a youtube video showing you how to fix your phone, There's video's down the right side you can check out as well....CHEERS..
Apr 18, 2016 | Tablets & eReaders
I turn on my zeki 7' dual core tablet and it turns on but stays on the zeki logo screen and wont load..
Go to this site for the instructions on how to do a hard reset on your tablet.
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Dec 31, 2014 | Zeki Berk Ulu TBDG773B 7" 8 GB Black...
My Zeki tablet screen is black, red and white. Can this be fixed?
It is possible that the digitizer connection has become dislodged or gone bad. Go to this site and watch the video on how to fix the digitizer.If the tablet is still under warranty you may want to contact the manufacturer before attempting to fix it yourself. https://www.youtube.com/watch?v=YOFqSstNNg4
Dec 04, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
None of my apps will turn on and it keeps saying all apps are closed
you might have transfered it to lacal sd card which are transfered to some other location
from file manager look wether all files are there only where it was prior(since app follow the same pathway to load app)
try to relocate it on prior position
or else you have to reinstall them
remember alway keep your backups
Feb 01, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
Can you download apple apps on a zeki tablet?
no, absolutely not (only with an emulator, see 2nd link)
as Zeki-tablets use Android OS
- however many apps exist in iOS, Android or other versions
you need to check that with the built in Amazon App store
Ask Mama Reviews
iOS Emulator for Android APK Download Run iPhone Apps on Android Phone download-apple-apps-zeki-tablet-oawkhf2sylgpmq5puvpglfxy-3-0.jpg
Nov 28, 2013 | Shopnbc Zeki 7" Multi-TouchTablet
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Zeki Berk Ulu 8GB 7in WiFi Android Tablet - Black/White Logo
431 people viewed this question
Top Zeki Berk Ulu Tablets & eReaders Experts
ray gallant
 Gary Gemmell
Gary Gemmell
FiFo
Are you a Zeki Berk Ulu Tablet and eReader Expert? Answer questions, earn points and help others
