Does anyone know how to install a true bypass switch and an led on a vintage mxr chorus pedal? I've seen different articles but none that could fully explain what to do. I'm pretty handy with a soldering iron and understand how to install different components fairly well. All I need is instructions on how to grab power from the rails to power the led and how to wire the true bypass switch. Thank you
SOURCE: MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
